Step 6: Confirmation page will open then click on the Wipe to reset.
Step 7: After clicking on wipe your device will turn off and it will start wiping your all data including all Patter/Pin/Password. This process will take time so be patient, after wiping all data device will reboot into initial setup.
You are done! You can also use this method to wipe your device if you lost your device!
